Detection zone won’t save - Cam V2
Wyze Cam V2 firmware 4.9.9.2351 My detection zone won’t save. I get random squares
  1. Set a new zone. Appears ok.
  2. Save - Appears OK
  3. Leave the setting area
  4. Return to the detection zone setting - all random squares, have nothing to do with the original set.
    Power cycled, rebooted camera, phone, etc
TOTAL DETECTION failure, Again! Reset squares, unplugged , reset, cache cleared… NOTHING. Only happens on 1 cam. NOT my wifi connection.
Tech support focused on the app, not the camera itself, and suggested to uninstall/ reinstall the app (Android). I tried my wife’s Iphone, and it worked. So it smells like the app. problem.
AGAIN, same problem- DETECTION ZONE WONT SAVE- again, since your last FIRMWARE UPDATE, the issue has gotten WORSE. clearing CACHE, checking all DETECTION SETTINGS, results in NO EVENTS, due to your APP FAILURE. Wi-Fi is solid,
PLEASE FIX THIS! your WYZE CAM 2 is useless without working DETECTION ZONES
EXACT same issue here. It is BEYOND frustrating. I have 2 iOS users in the house, I’m going to try setting it on their devices. But if that works, should it really be the fix for this problem?
v2 4.9.9.3006 Android app 2.50.2.442
I made a minor revision to a nicely functioning detection zone, seemingly without issue. Saved and rechecked just like the OP.
Realize five days later that I’m not getting any detection notifications at all on this not-that-active cam.
Check zone: a single square at the top left corner is all that’s active. Revise, save, back-out, back-in: Zone seems to save but doesn’t, the top left square persists.
Power cycled cam, reinstalled current app, same result.
Installed a prior app, several versions back - 2.49.1 (390) - no joy.
Recommendation: Do not make a minor revision to the dodgy v2 zone. Live with what you’ve got.
