I have a front yard garden with zone restrictions that limit my fence height to 4 feet and a deer problem.
Does anyone have experience using a wyze cam to detect deer and trigger an automated event? Maybe turning on a sprinkler or making a scare crow pop up?
Not sure if Deer are scared off by a siren, but the Wyze V3 Camera has a siren on it (80dB). You could setup a detection zone on the garden that turns on the siren if motion or a “pet” is detected.
A sparrow tried to take up residence in my v3 equipped bluebird house. Blasted the siren, which had to be deafening inside a small box. Didn’t faze the bird at all. Had to open the birdhouse and clean out the nest.
Had some crows totally decimate the sunflower seed tray. Have a WOC pointed at the tray to monitor the seed, because the squirrels make me put the tray on a 10 foot pole.
They jump high when popped with a 22 caliber CO2 pistol
I’m not aware of a Wyze mailbox sensor or a garage door tilt sensor.
My smart home runs on Hubitat Elevation. I am also an Addams Family fan (TOS)
After a week or so of getting woken from a nap by ‘whoop whoop whoop Mail’s in’ I changed it to a chime. But the bigger issue was getting the signal from inside a metal mailbox that is inside a brick enclosure was challenging. Had to put a bulb that is a repeater in one of the post lamps in the front yard, Then I drilled a hole in the metal mailbox all the way inside just large enough for the motion sensor to fit into and also not be shielded by the metal mailbox. After a few weeks the humidity inside the mailbox corroded the motion sensor. I replaced it and put it inside a Ziploc bag.
So even if you put a camera inside the mailbox, I doubt your WiFi would reach.
