I’m glad to hear that it worked. Have a good day.
I’m also having this issue.
- App version: 2.29.0
- Ghost Rule name: wake up (all lowercase)
- When did it happen? Not sure. Plug is used to help my kids know when to wake up. Only noticed when I tried to change it 2 weeks ago. Tried to delete rule and create a new one. Didn’t help (new rule also works).
- Sent under 509755
Thanks
Hi @semmelfc sorry for this inconvenience. We’ll look into this issue as soon as possible.
@semmelfc did you share your device with anyone? According to your log, it worked well for Turn on and Turn off. While we found another user created a smart with this device. Let me know if you have any other questions.
I shared the device with my wife. I will check her app.
@QiS I am experiencing the Ghost rule as well and hope you will be able to assist. Running 2.32 app version, ghost rule “Work”. The rule was deleted probably close to over a year ago. Log ID: 620473
Thank you!
I have created a support ticket because I am experiencing issues with rules. I confirmed I have the new rules engine. App Version is 2.32.0.
Hello. I also have a ghost rule issue. I set the camera to trigger alarm when motion detected in a range of something around 11pm and 5am.
I deleted the rule, uninstalled and re-installed the app, reset the camera and clear cache, but still I have it triggering at night.
I’ve turn it off long ago because it didn’t allow me to sleep in stormy nights. But I tried it recently and still the same issue.
Firmware version: 4.36.9.139
I’ll very much appreciate your help.
Attached you can see the log that was showing up when it triggered:
Some one than can help me with this please? It’s been long time not being to use this camera… new versions installed and the problem persists. Thanks.
I have a fail safe sure to work solution, but it may not be practical for you or others with this problem.
If you do not subscribe to any WYZE services, you could simply create a brand new WYZE account (using a different email address than the one tied to your existing account) and then setup/move all of your devices to that account. This would also force you to recreate all rules/schedules/automations that you actually want.
Again, that is not practical if you subscribe to WYZE services such as cam-plus. As far as I know, subscription services cannot be moved between accounts.
Maybe WYZE could offer a “reset my account” feature with loads of disclaimers?
