Date Playpack
I have a 32GB micro sd card that is set to continuous recording, and when I select a date on playback it goes to the day before at 5pm. I select April 15 and it goes to April 14 at 5pm and so on and so forth. I do not remember this being a problem before and it happens to both my V2 and V3 cameras, so it’s definitely software side that is causing this issue.
Yep. Confirmed. I just loaded one of my V3 and entered playback from the Livestream. Select a previous day (15th) and it pops up the 14th @ 8am.
Definitely a bug. Not sure if its an old version bug though.
@WyzeJasonJ: can we tag this one a bug and run it up the flagpole? Thx!
Android 2.29.1.116
FW: 4.36.8.32
App Log 544904
Cam Log 544903
@SlabSlayer
I believe there may be an updated app, 2.29.2.127, in this version I cannot replicate the issue, are you able to update and do you still get this issue?
Wilco. Update tonight and will report back.
@brianyu00, what is your app version? See Jason’s post above.
Updated to 2.29.2.127.
No change. See video screen capture demonstrating this.
When opening the SD Playback, it locates to current date, 18th. I selected the 16th. It pops momentarily to the 16th, then immediately reverts to the 15th. It does this regardless of the date I select.
Hey y’all. This has been posted to the Fix it Friday thread. Go there and vote for it with a like and add a post if you want it fixed.
