Mine works great. No issues so far.
Just got mine this weekend and it is great. Only issue I have with it is on the regular mode it seems to have a short battery life. Anyone else have issues with battery life? I believe their specs said 25 minutes on regular speed, and I only get around 12. Still love the vacuum and it has been great so far!
Yes it is ridiculously short . If you just want it to vacuum a small bathroom its perfect. The real crappy thing is I waited for months to get it and now that I got it I find out the battery sucks! Then you think well Ill get another battery , Why ? then you will have 2 crappy batteries , and to top it off YOU CANT GET NEW BATTERIES! What a waste of time and Money !!!
The 1st time I used mine, I tried all speeds to make sure everything worked. The battery lasted about 6 minutes. The next time, I used medium and turbo. That lasted about 10 minutes. It’s gotten progressively better with each use. Last time I used only medium and it lasted close to 25 minutes, good enough for 1 of 3 levels. Definitely need a spare battery or 2, but I’m happy with mine.
Can’t say how long the battery lasted but I was able to get my whole place + stairs.
About 1000sqft
Bottom floor all wood with rug in living room. Wood - eco mode is perfect for dog hair. Used normal/medium for rug.
Stairs are carpet - used turbo for all 15+ stairs.
Upstairs carpet, normal. Upstairs flooring, eco mode.
Ended up with 11%
I’m pretty impressed with it so far and, know to take special care of any seals, o-rings and the like so it will continue to be impressive. I like that the attachments clip onto the wall mount as well… Very handy. It took me a little time to examine how the battery has to be reattached, sliding it in it’s proper grooves from further back than I’d initially imagined… Once you do that it’s smooth sailing though.
Another Wyze product that works in this household.!
I still say the cordless vacuum and the handheld vac are not meant for folks with dogs.
I used to broom sweep our hard surfaces every evening. Both work but there is not enough power to get it all.
I have reverted to my Miele plug in canister vac- which is amazing cause it plugs in and lasts for a cleaning.
on both wyzee vacs, the battery power is short lived, the recharge time is SLOW. You better run thru your house to be able to cover all areas.
Totally agree and you cant get any batteries! Because Wyze sells their products before they stock replacement parts . Like filters and Batteries and more Im sure! Not Good Business!!!
I’ve been using the cordless vacuum for about 2 months now and it’s perfect for our 900 Sq Ft vacation home. Light weight and no cord make vacuuming almost fun. The battery easily lasts for the whole small home. For a larger home, I would probably opt for a plug-in vacuum rather than extra batteries.
