Cordless Vacuum S Replacement Parts Availability
When will you expect replacement parts for the Wyze Cordless Vacuum? I am specifically look for the Floor Brush - not the entire unit - just the brush. It looks lit the head unit is out of stock which would likely include just the brush as well (which I don’t find on the site.) Wyze Cordless Vacuum - Floor Brush – Wyze Labs, Inc
The head has seized up and no long rotates. I have worked directly with a support person and replacement is the result. If the brush is not available, could you point me to an after market or similar brush that will work in the vacuum so I could purchase as a replacement?
Thank you
I had the same problem. The brush seized and would not come apart. They took it back under the 1 year warranty and sent a new one.
