Cordless vacuum quality
Hello,
I’ve been looking into buying the Wyze cordless vacuum but have read different reviews on here that the parts are cheap and break off easy.
I’m just wondering if the accessories that Wyze has for the cordless vacuum are all the replacement parts needed or if there’s certain parts that break that you cannot fix/buy a replacement for?
I don’t want to get stuck with a broken vacuum that has little to none replacement parts.
Thank you
