Wyze Cordless Vacuum Cleaner
I would like to ask as to where can I buy the Wyze [Wyze Cordless Vacuum Cleaner Dust Bin Collector? The dust bin collector’s locking mechanism (the one that holds the bin to the vacuum stick) cracked so the stick can’t hold and lock the bin collector to the stick (I’ve attached a picture of what I am talking about).
And in order for me to be able to use it still since I can say that it is still a good vacuum cleaner I have to tie it around with a rubber band so that I can still use it…
I’ve looked and searched all over as to where I can buy a replacement part for it, but so far I cannot find it anywhere…
I wish Wyze could at least have some replacement for Wyze Customers/users to purchase…
darn it, I think because your account is so new you dont have the Proper trust level the form requires to upload a photo. This is done as a way to cut down on spam and Bots, and for years it’s been quite effective. But sadly for certain situations just like this one it does hinder us a bit. But I believe I know what you’re talking about, sadly i looked at the replacement parts section here,
replacement parts
I’m not seeing that one.( what I Believe you are talking about at least) I’m guessing because that is more or less seen as the body of the vacuum, that’s probably seen as a non-replaceable part as in normally doesn’t break and I stress that normally part.
if you have a dropbox or something similar you could post a link to your picture, There are a lot of people on the forums here that like to tinker with things and maybe we could come up with some solution not necessarily approved per se but something that might work. We just need to be able to see which part exactly broke.
and welcome to the forums!!!
I had this problem 8 months ago and no one had any in stock. Searching led me to AliExpress and so I bought two of them. They seem to fit fine.
https://www.aliexpress.us/item/3256805941656318.html?spm=a2g0o.productlist.main.3.184a3Bu43Bu4Hj&algo_pvid=40be99cc-de4e-46e0-be1f-c7f8c831eca6&algo_exp_id=40be99cc-de4e-46e0-be1f-c7f8c831eca6-2&pdp_ext_f={"order"%3A"2"%2C"eval"%3A"1"}&pdp_npi=4%40dis!USD!64.66!32.33!!!460.52!230.26!%402103201917515596625258821e1c7a!12000035880735880!sea!US!6268637656!X&curPageLogUid=E5eCpZI5cPsN&utparam-url=scene%3Asearch|query_from%3A. Last I looked, they were $32.33 with import tax included and about 2-3 week delivery to east coast. Good luck!
