Apologies if this is an obvious question or a known issue, but I’m having trouble getting my pan cameras to record continuously on their mSD cards. I have had this issue since the beginning with my Pan v1, but am now seeing the same thing with my new Pan v2. Event recording seems to work, but if I scroll to “view playback” it tells me “no video at the selected time” and there’s no blue color coding on the time scroll part.
Not sure if this matters, but it is mounted in a location with okay-but-not-great wifi signal strength (2/3 bars in the Wyze app). However, if I bring it to where the signal is strongest I’m not seeing any difference.
Sometimes reformatting the card (a couple of times?) and/or restarting the camera seems to help. I’ve tried a couple of different SD cards, from 32-128GB and that doesn’t seem to make a difference. Does anyone have more tips?
Have you tried taking the card out of the working v1 and putting it in the v2 to see if it’s a card or camera issue?
Yes! I’ve tried a variety of cards in both cameras. Usually the way it works is that I’ll try a bunch of stuff (reformatting the card, restarting, etc) and it will seem to works for a day or two then stop working again. Sometimes it also looks choppy like it is recording intermittently (see pic)
That’s odd that it seems to be the same length and same gap between recordings. Does it look like this on your other cams as well?
Nope! Just this one – weird huh?
Reviving this thread to say that I’m still having continuous recording issues on all of my cameras – the Pan, Pan v2, and the v3 as well. I’ve tried a variety of SD cards (some 32gb as recommended, some larger) and no combination seems to have done the trick. Reformatting the SD card and restarting the camera sometimes fixes it for a short period – I will be able to see playback for a few hours. But the playback feature generally doesn’t work reliably. The cards seem to “fill” as if the continuous recording is indeed happening locally, but playback on the app says “No video at the selected time” at least 95% of the time for all of my cameras. This is very frustrating! I am on the Beta version of the app. Do people think this is a hardware problem (camera or SD card), a software problem (permissions in the app?) or a cloud services problem? If it matters, I have cam lite on all my cameras, but am not a services subscriber.
