EVERY POWER OUTAGE cams wont reconnect on own have go thru whole setup process every time
Are you using the battery powered WCO version 2 ?. I have four of the WCO v1 cams and they normally come back on line after a power outage and I have never had to set them up again. Two cams load as soon as the base is back online and has a solid blue light and the other two take a few minutes. If I get tired of waiting I just go out and turn the power switch on the camera off then on again and they come back instantly.
Shouldn’t have to; did you try rebooting the router instead? Rebooting the router normally isn’t needed, but maybe your router does?
In over 7 years and 55 cameras I have NEVER needed to redo setup after any power disconnection. Note, I do not have any battery cameras.
