I have a Wyze cam that I previously set up in my office, but I want to give it to my mother for her house. She does not have an iphone. Can she take it home and plug it in, and I connect to it from my house? Or do I need to be on the same network in order to set it up?
during setup. you have to scan the QR code…what I typically do is add my SSID/password to the new router & make it hidden, then it will connect without setup. Or if you know her SSID/password, add it to your router, setup the cam then give it to her to bring home.
Thank you so much @Ken. This is very helpful!
~ Breanna
