I had to change wifi, and now canot work out how to conect my Cam to the new Wifi.
I’ve restarted the cam and Reset, but I cannot find any setting to connect the new WiFi
You need to go through the setup procedure as if it is a new cam. As long as you name it the same thing, it will retain its settings in the app.
Thanks, that was relatively painless
The proven easiest method is to keep the same wifi name. But I also change mine for something different when I get a new router.
In reality, it is a good idea to change the password from time to time anyway, which will require the same process. Would be nice if Wyze (and MANY other IOT brands) would make it easier to update your SSID or password.
