Connect an External Speaker
A usb port to connect to an external: VAVA VOOM type speaker? OR any other external type speaker to get a VERY LOUD sound output?
Not sure if the existing usb port will do this?
Current speaker is good but sometimes i would like to connect my wyze cam audio to an external speaker so people in place can hear me easily. so it would be great to include a 3.5 mm Jack into the cams!
I would like to add a wireless speaker and the sound needs to be improved I can’t hear what the other person is saying. And it would be helpful if we could add a wireless speaker to boost sound and talk into.
Hi Wyze,
I would love to be able to talk to people (“You are on a private property, please leave :slight_smile:!”) . Currently it is possible, but I need to shout into my phone to have a almost ok sound from the builtin speaker.
Maybe a mini jack female plug would be a solution.
Also according to IA, we could have pre-recorded messages that would be triggered upon detection of a person. (“What a new killer function!!! well done William!” :slight_smile: “Thanks Wyze team:”).
  • “Hi, Welcome in the Parker’s villa. Please follow lights and enjoy cocktails”
  • “you are not welcome, please leave!”
  • “Smile, you’re being filmed”
  • etc…
SD card could have these audio files in a folder in order to ensure the less latency and the best reactivity.
Thanks, you’re welcome :relaxed:
Kind regards,
William
I would like to see the external speaker as well. Along with the mic. I want it for keeping an eye on my mom that is disabled. Her hearing and speech are not good so the availability to add good external audio would make this AWESOME.
PA speaker or Loudspeaker
Wyze needs to create a wifi PA speaker or Loudspeaker. The teeny tiny speakers in the cams don’t cut it when you need to alert someone across the yard. They work fine if you hold it to your ear like a phone, but even the siren is pitiful. Use a speaker like the 8 watt PA/external speakers like used used on CB and Ham radios. The microphone could be better, but it is funny when someone comes to your door and you try to talk to them and all you see is their ear. Vote to make a wifi PA speaker that can be heard clearly across the yard!
