Confirming I can have cam pro ring in duo door bell pro wifi chime
I am going to buy the dual cam door pro doorbell. Comes with a Wi-Fi chime. I also want a second doorbell, but I don’t need the dual cam. I want to be absolutely sure that I can buy the normal pro cam single camera and have it ring on my Wi-Fi chime that comes with the dual cam. I wanted to ring when someone presses the button not just out of automation that it recognizes a person is there. This is a critical thing. I wanted it to work smoothly that at either doorbell if the doorbell is pressed that the chime will ring instantly. Well, this work this way?
I believe the WiFi chime works with the other doorbells. Based on my experience, however, there’s some lag. It isn’t like when the chime is hard-wired.
