Compatibly of v2 outdoor and v3
Can I use a v2 outdoor cam instead of the v3 for the garage door opener set up?
Welcome to the Wyze User Community Forum @littlerudegirl33! :man_raising_hand: Glad you are here! :grin:
The Garage Door Controller is specifically designed and programmed to work with the Firmware on the V3.
The V3 that comes with the GDC is also a specially designed V3 with a specific power cord to work with the GDC.
https://support.wyze.com/hc/en-us/articles/5517143472411-Does-it-include-the-same-Wyze-Cam-v3-I-already-have-
It also doesn’t work with Cam V3 pro either. There should be a warning when you try to purchase only the garage controller alone that you should not try to use with existing cameras or purchase cameras separate from the bundle. I am so annoyed. Everything is harder when you order from Wyze. Pita.
