Comcast xfinity customers- DO NOT buy /use their pods to boost your wifi signal!
I hope this will save anyone who uses comcast xfinity as their ISP time & money I have wasted! I had 2 Wyze cam pans connected that worked great until comcast had me upgrade my modem to a dual band modem (uses both 2.4 & 5 GHz networks). We were sold these little things they came out with about a year ago called “pods” that help boost wifi signal in areas of your home w/ weak signal. Fast forward. . Today i called comcast to get help reconnecting my cameras. I tried several times- it works up until I get the message announcing, “QR Code scanned please wait”. Then it says, “Can not find specified network”.
Comcast said they can help me “separate” my network so the Wyze cam pan can connect to the 2,4 network. Unfortunately I can not do that using those pods. Ugh! They make customers buy 3 pods at a time for over $100 and you can only return them for 30 days. I do plan to remove them from my network so that I can get the Wyze cams re-connected but first I need to do some research and find a suitable signal booster to replace the pods. Of course comcast can not suggest one as they will only recommend their own product. So frustrating! Hope this makes sense.
Recap:
So if you are going to get/ upgrade to a dual band modem make sure you can “separate” your networks since Wyze can only connect to a 2.4 network. Comcast customers should not use/purchase pods because then you can NOT separate your network and Wyze can not be added to home network.
I’ve been so happy & impressed w/ Wyze cam pan- the price & ease of use & reliability have been excellent! I had one Wyze cam pan set up outside over my driveway using the black silicone case and it stood up to severe heavy wind & rain storms since March as well as daily moisture from fog here in San Francisco! That’s why I’m keeping the Wyze cam pans & ditching the pods from xfinity!
These kind of things are exactly why I have never used Comcast equipment for my Internet , I have Always used my own Internet equipment many, many years
Yes, I started buying my own separate equipment when I noticed I could pay for it in less than year compared to rental charges. I currently use a Motorola modem and Netgear router on my Comcast connection.
Thanks for the heads up on the pods!
Are you saying the Xfinity Pods operate only on the 5ghz network? I am not arguing, just trying to understand for clarity.
Can’t you separate & turn off 5ghz to make it the same as the old system?
Comcast is going to get so much grief for that. Millions of internet connected devices are purchased every day and the majority of them only work on a 2.4 connection.
Is this something that Comcast/xfinity can solve, or is this something that Wyze can solve? I don’t understand the reasons why Wyze can only work on the 2.4 band, nor do I understand why the xfi pods require merging the two wifi bands, but I do think Wyze has demonstrated better customer service. I have been trying to contact xfinity to ask if it is possible to disable the 5.0 GHZ band, but can’t get an answer from anyone…I would like to hear if anyone has had success with a workaround.
I posted this on another question in the forum, but I successfully installed 3 xfi pods and was able to keep my Wyze cams working. I think a key was that when I merged the two bands I used the existing SSID and password for the 2.4 GHZ band, which is what the Wyze cams were already using. The benefits of the “broadband steering” that the xfi pods create is that you are automatically using the best connection at any time, and don’t need to reconnect, but this means you are never sure if you are on a 5.0 or 2.4 channel. Apparently the Wyze camera only recognizes the 2.4 anyway. If I need to restart, move or reinstall the cameras I am hopeful that it will also go smoothly. And yes, the speed and reliability of my wifi connection has improved (especially in dead spots) so this seems to be a good solution.
xfinity update…
Just login to your xfinity xFi online and go to:
  1. Network
  2. Edit WiFi
  3. Check the Use different names and passwords for 2.4 GHz and 5 GHz WiFi
  4. Name the two differently and put the password you like
  5. Click Apply Changes
By they way, My (made for indoor only) Wyze cam pan in the black aftermarket silicone case is still working perfectly after all this time set up outside above my driveway! It’s about 3 years last March!
Buy , set up , and run , your own equipment , and be happy :smiley:
And let the higher-quality equipment pay for itself by not having to pay rental fees to Comcast. :slight_smile:
I know this is old but ive had xfinity forever and any modem/ router you buy or rent from xfinity has the ability to seperate or use a single bandwidth. Their modems operate the same way as the ones you get from the stores as far as basic functions go. To disable bandwidths you need to log into your modem using the 10.0.0 login while you are connected to your network and then login using admin and password from there you will have tons of settings including the ability to lock the modem into a single bandwith. If you arent savy on this type of stuff then just look at some youtube videos. I currently am running 7 cameras and one outside service ip camera on my network
