I have a 5 Wyze cameras, mixed indoor and out. Twice in less than 24 hours they have all powered off on their own. Any explanation or fix?
Welcome to the Wyze User Community Forum @ann.m.marr!
The description of your issue is a bit too vague to pinpoint a root cause. Can you provide a bit more detail?
What cam models are you using?
When you say “Powered Off” are they showing in the app as “Off” or “Offline”?
If you have the status light enabled, is it off as well?
What gets them back on? Clicking the On button in the app? Using the Restart feature in the app? Physical power cycle?
Do you have any rules saved that have actions listed as “turn off cams”? Check your Rules History for any possible actions that would have done this as well.
Are your cams shared with another user?
