V3 Cams keep turning off
Is this the same issue that is being reported? I open up Wyze and the cameras are turned off and I have to press the virtual “on” button to get them back on. All my cameras. Isn’t WIFI. Isn’t power.
I have not experienced this issue before. Have you reached out to Wyze on this?
Do you only have Cam V3’s or other cameras as well?
Is there a certain time this is happening at? What rules do you have and use? What does your rules history look like? Anyone else have access to these cams? Via your login or through a shared device?
Just V3s. I have eight of them. Wyze pushed me to the forum.
Right now they are all working (well, of course they are!). I don’t know if this was on Wyze’s side or not. I do not use rules. My wife also has access but not been turning them off. Login is separate (iPhones). And not a certain time that I can tell. Again, right now they are back to normal working operation. I’ll keep tracking.
