Color Lightbulbs Randomly Turn On and Change Colors
I installed 2 color bulbs about a week ago. They initially worked fine. Now they have started turning on by themselves and changing colors on their own, sometimes quite rapidly.
I have no rules setup, no automations, and my app appears to be up to date.
Are you able to suggest a fix?
Welcome to the community @kcoerr
What I would try is pairing the bulbs again. you can leave them connected or delete them from your app. Since you do not have any rules or automations you can try either one of those. If you had rules and automatons, I would recommend not removing the bulbs from the app.
Here is a link to perform a factory reset of the bulbs:
Note, if they are in a lamp, might be easier to unplug the lamp 3 times.
I have 2 color bulbs that randomly turn on. All settings are correct. And I have repair them
I have this same issue. I set up an automation for Christmas to make it green and now I disabled the rule and have since even deleted the automation altogether, yet every day it still turns back on green. I don’t see anything that would still be causing it, and have re-paired it, yet still persists with the daily green light at my front door haha
Same issue.
Why are there zero solutions? Factory reset doesn’t help.
The one thing that comes to my mind when reading this is the possibility of a “ghost rule”, as mentioned here and elsewhere:
