I set four Color Bulbs to bright white. One color bulb out of four won’t retain its settings and sets itself to blue after about five minutes. When I try to reset it, it also doesn’t have the same response to the settings as the other three bulbs. Even when I select the whitest and brightest setting, it doesn’t get any whiter than a pale white/yellow. Now two other bulbs have started setting themselves to the pale white/yellow. They don’t go blue first. There is also a periodic flash, but I can’t tell which bulbs are flashing. Has anybody else experienced this?
What app version are you using, and what firmware version is on EACH bulb? Don’t say “up to date”, please say actual version numbers.
Thank you for the advice. It is interesting that “up to date” is a direct quote from the app.
But, to be more precise: each bulb is using version 1.2.0.339 and the app is 2.24.14.
Also, I have tried deleting and re-adding the bulb. I just turned the light on and today the one bulb started off more yellowish white than the other bulbs, even though I have the color set as green (for testing purposes). It then changed to the blueish color. I can’t set it to pure or bright white on the color wheel, no matter where I move the cursor.
Yes the app says it, but all different apps can say up to date. There is a production up to date, a beta up to date, . Some products also have more branches like v2s have RTSP, which always said up to date, but is actually way behind current firmeare versions. It also future proofs your statement, where as people reading your post in say a few months or more etc would only see “up to date” and think it’s current then but it’s not.
Thanks for that info. My theory went out the window. I experience what you are when one or more bulbs are in need of a firmware update. my wife will use Alexa to turn on a group of lights, and I’ll notice that not all of them are the same hue or color. I’ll know then that a firmware update is needed on my end. Since all your firmware versions are current, I don’t think that is your issue.
One thing I did notice is that your using the beta app, but have production firmware on the bulb. Are you sure there isn’t a pending update?
Thanks for the response. There are no updates for any apps in Play Store. When I check for updates on each bulb individually, the app states that they each are up to date. Is there another way to check?
You are probably using the beta app but not have set the bulbs for beta updates, to check this, in the app click on account (lower right), scroll down and click on about (very bottom), click on Beta Program (again the bottom and set up the products you would like to test firmware on. Just be aware this can also bring unintended bugs since they are beta.
I also have the beta app and my bulb firmware is above what you posted. @WyzeJasonJ is right on, make sure the bulbs are selected as being wanted to update as beta in the beta app.
All the bulbs are now on v1.2.0.364. Wyze app remains at v2.24.14.
Blue bulb still turns blue. And now the last bulb to not change has decided to join the team and turn a yellowish white after a few minutes.
Any other suggestions / ideas? I was very excited to get the color bulbs, but now I am disappointed.
I have the exact same issue with 2 of my 16 color bulbs. Have you reached a conclusion?
@shaunyouth - Thanks for reaching out. I have sent an email to Wyze Support to find out how to officially submit a defect report for the Wyze Bulb Color (beta).
Any developments on this? I bought 2 Wyze Color bulbs a couple weeks ago. One just started randomly turning blue. Firmware and app are fully up to date.
I’m having the same issue with two color bulbs.
I am having the same issue.
Mine flicker, change color, and sometimes turn off on their own. Can’t seem to fix it and it has been going on for weeks. Seems like a lot of trouble over a light bulb.
I am VERY disappointed in and absolutely do not recommend this product. With a 75% failure rate, they are definitely not ready for prime time. Nine months (and counting) is way too long to take for a resolution.
Dang, this is biting me now too. Guess I’ll contact support.
I’ve verified all bulbs are on Firmware 1…2.0.435 with plugin version 2.34.0.2. All activated on same date earlier this month. 2 of my 13 are doing it.
Add me to the list.
Stuck on green here and won’t connect to the app. Well it says it’s connected but I can’t control. Had two other bulbs randomly do this, one stuck in blue, the other green. Then it finally fixed after a month.
Now this bedroom is stuck at green even after deleting and re-adding multiple times.
Ugh. How annoying! 10 bulbs deep, more time than I’d care to admit on running updates and troubleshooting, and a fistful of cash gets me different colored bulbs with minds like my children, doing anything and everything they want which covers everything under the sun except what I ask them to do.
Pulled out of beta, updated all my equipment…no change whatsoever, well, I take that back, they change back to whatever color they want faster now after changes are made in the app. I feel like I should be dropping tuition money while they call me by my first name as well! HELP! My love life is taking a sever hit here people! That tends to happen when your bedroom is bright as the noonday sun with no ability to change them or turn them off…oh yeah, have I mentioned that? Can’t get my lights to stay off either, woo hoo!
