Wyze Color Bulb v2 & Color Bulb BR30 Firmware Beta Test 9/10/2024
Wyze Color Bulb v2 Beta:
Version: 1.0.2.51
What’s new:
  • Bug fixes
Wyze Color Bulb BR30 Beta:
Version: 1.0.1.51
What’s new:
  • Bug fixes
What bugs?
I’m only guessing, but based on some recent discussions, I believe some people were having problems if they needed to go through setup again and having setup fail (ie: If you removed the bulb from the account and then tried to set it up again, or needed to go through setup for changing Network SSID). I’m guessing this resolves that issue to protect people’s bulbs to be able to keep working. But I am only guessing.
Updated 2 Color Bulb v2 bulbs from 1.0.2.14 to 1.0.2.51. Initial functional tests related to Wyze app and automations/trigger tests checked out. Not sure what I’m really supposed to be testing though. Pure blue is still slightly off compared to Color Bulb v1, as previously reported.
I think that was the V1 white bulbs, but not positive on that.
Makes sense. I mostly skimmed through that thread lightly which I often do when I see capable users/volunteers or employees who I have full faith in are already involved. So I couldn’t remember all the minutia and this was hedging my response as I wasn’t actively involved in that issue.
I was definitely involved with that V1 white bulb issue. Turns out I only have V1 color bulbs so this doesn’t apply to me anyway.
Interesting about the blue color where when I did a search for the difference between the V1 and V2 color bulbs, someone showed that the orange was actually better on the V2 than on the V1.
