Color Bulb issues
If you are having trouble with your color bulb. It gives you the option to Delete device. Delete and re-enter it again. It worked for me hope it does for you.
However, my issue with light is it’s not giving me any other option but to update my firmware and it won’t update the firmware even though one of the lights it’s already updated the firmware therefore, I can’t even tell it to delete the item
Option to update ear firmware, check what it’s giving you the option to update to and then go into your device info and see if it’s already updated to it. This is something we dealt with many years ago and I haven’t heard of it recently but it’s something to be aware of that it wasn’t ever in the past that would prompt you to update even though you were already running the latest.
After noticing the congratulations prompt, I deduced that the app had been updated. About ten minutes later, the light flickered briefly. Since then, whenever I open the device or a group, the update prompt appears instead of any options. If I go to the update page, I can exit but not return to the devices page; instead, it redirects me to the main devices page. Additionally, I can’t access devices within the group. I tried creating a new group for them, but it said they were already in another group. As a precaution, I thought about deleting the app to avoid data loss, but it might prompt me to erase all data. I’m currently waiting for log requests.
So, here’s the thing - I can’t delete the update pop-up.c It’s like it’s stuck on me, and I can’t get rid of it. I tried everything, but nothing works. If I try to update the device, it takes me to the update screen, and I can’t get back to the device’s options. It’s like I’m stuck in a loop. And the worst part is, I can’t even group the other things I want to update without that group. It’s like the update pop-up is holding me hostage.
have you tried deleting the group and doing the update? you can always remake the group.
if you could, record your screen and upload it, I THINK i know what you are saying, but im worried I might be missing something.
