Does anyone know if there is a way to change the network a cam is on without re-installing it thru setting it up again? (Poor connection on one that takes a long ladder to reach!)
If the new network has the same SSID and password, then usually no. If you are changing those, then you will have to re-setup the camera in the app on the new network.
Thanks for the reply! To clarify, I am changing from the primary ssid broadcast by my router to the ssid broadcast by my range extender. Same pwd, same ssid except the extended version adds ‘_ext
‘ to the primary ssid. Not a mesh extender.
Unfortunately, to the camera, that is a different network. I know this because I have 3 different SSID my cameras are connected to. I wish I could tell you something different.
Sigh… I hate ladders I was afraid that was the case but with all the tech savvy out here I thought I would ask. My provider offers a mesh extender-think I’ll look into that.
Thanks again!
You’re welcome!
I think I am going to try the mesh extender. I will keep you posted as to how well it works.
