Changing Network via App
I have been waiting for Wyze to roll out the ability to change your Network, but all my cams except Cam Pan V3 still have the ability grayed out. I have V4s, OGs, Battery CamPros, Cam Plus. None of these are showing this. This topic has been talked about for some time, but now July 2026 I still have not got a update, Is it the “version:” issue, is it the “Firmware” issue? Is it the camera type issue?
This is a user picture showing his V3 having this ability. None of mine except Pan Cam V3 show this option. When will my other cameras get this ability?
Based on how it rolled out with Cam Pan v3, I suspect it’s a combination of firmware and app:
Only someone from Wyze could answer that, but you could set your Forum preferences to track announcement topics in Wyze News and Beta to get a heads-up about when this feature might be expanded to other Cam models.
Yep, my PanCam3 is the ONLY camera that has the changeable network ability My App Version is 3.16.0.980
My Apps get updated every day but havent seen one from Wyze in quite sometime for all my other Cams. Maybe they will eventually roll out for the V4s and Batter cam Pro?
Since it’s available for Cam v3 and Cam Pan v3 now, I’d expect to see Cam v4 and Cam Pan v4 have that feature at some point, but that’s really just speculation on my part. I have no idea about where Battery Cam Pro or things like Cam OG and its apparent offspring (e.g., Window Cam) are on the roadmap. They’ve even done it (offering a network change feature) with recent lock products[1][2] but it works differently there, because the app prompts the user to press a button on the device, which makes sense for a lock product that a user is expected to be able to touch anyway—not so much for a Cam that may be mounted in a location without easy-to-touch access.
  1. ↩︎
  2. ↩︎
