I haven’t been using the Home monitoring for a few months (ended subscription), Today when I attempted to test the system I keep getting wrong PIN error, maybe I forgot. I went to the app to try to change it but the setting is no where to be found. Is there a different method for changing PINs in v3?
Without a subscription the keypad is useless and you can’t change the pin. Actually, the entire system is useless. It no longer functions as an alarm and even test mode is unavailable.
Thanks! I just renewed my subscription and everything is good now.
