Change volume of speaker and microphone
There can i change the volume of speaker and microphone ?
Se images.
There is no Wyze App settings for these. The speaker on the cam and the mic are set to a non-adjustable setting in the firmware. The speaker on your phone is the only volume adjustment available.
What sense does it make.that so many people are totally complaining about the cameras speaker volume and wyze doesnt fix the issue with an update? Theres always some random updates that doesnt do anything on the consumers end of things and we are the ones who have paid our money for the device why shouldnt we be listened to aboutbour dislikes etc or be honest on the outter packaging thats clearly displayed to a buyer so they can see before purchasing that the speaker volume on the camera can not be adjusted so that way if someone doesnt want to own a camera that they can not adjust thr volume on then they can make.the decision before buying it. I would never gad purchased mine had i known it could not be adjusted at all.
Do you know off hand any camera brand that allows you to adjust volume on speaker/mic?
The hubble app for motorola cameras actually does allow it and to adjust both individually to separate volumes to users likings
These cameras have a tiny little speaker and even tinier little microphone. Turning the volume up on either one would likely just result in distortion.
My OGs and PanV3s are sufficiently loud for what they’re meant for, I’m not expecting someone down the street to hear me clearly, but they pick up pretty good audio on recordings. If I really can’t make something out on a recording, I can play it back on a PC with headphones or on the big speakers and pick it up that way.
