Wyze Cam Audio very low after update. Android
Greetings,
For some strange reason the volume is not adjustable now after the latest update as of 16 aug 21.
The volume is fine on my phone by my tablet (which we use to monitor baby) you cannot hear anything. It now doesn’t adjust when you attempt to change the volume with the buttons. Is there an “in app” volume adjuster?
No I don’t have it on mute.
Using a Lenovo M8 tablet. 1 month old. Android 10.
Sound was perfect till update. Help?
Your “support” doesn’t have an agent and only leads to a U.S.A number but I’m in Australia.
You should know I love my WYZE cams…but would like audio back
Thoughts?
Thanks
Audio has been an issue for some time now, some of my devices are fine and other ones have this issue too. This has been an issue for me for many years, it started with the Pan-Cam and then V2’s and V3’s.
Seems to depend on the Android device for me.
Does anyone from WYZE jump on at some point to give any guidance? I don’t want to spend the time individually sending details of everything and not getting an answer. Clearly this is an App issue if so many people have it over time.
Is it difficulty to have a manual volume within the App settings?
Come on Wyze crew let’s get a fix going. I can see it’s been an ongoing issue with people for years.
Thoughts?
