I have Battery Cam Pro’s and Cam Pan 3’s. How do I capture a photo of someone in front of my house that happened a few minutes prior in the daytime? I do not see any past footage options to check. All have SD cards. I do not have detection on in daytime unless I am away.
If you are set for Continuous recording, you can tap on the SD Card icon below, circled in yellow. You should get the timeline below and pick and zoom there to zoom in. In any event, you should be able to go to the time and watch the video from that point.
Got it! Thanks!
This is
genius! I had no idea it was possible to zoom the timeline with a “spread” gesture here. Thank you for sharing this!
