Can't get sprinkler schedule to work
I am updating to 1.0.9. I will set a fake schedule for 15 mins from now and report back. Thanks!
I’m happy to report that 1.0.9 seems to have resolved the issue (at least for the first run).
Here are our logs for a successful run: 621158 . The run hasn’t finished yet, but this is the farthest it’s gotten since Saturday!
I’ll update tonight/tomorrow morning with results from our normal scheduled run.
Full successful logs from earlier: 621370
@norcal927 @big.budha Do you mind sending me a log? Thank you!
Updating the thread to report that our normal schedules started. Yay! Looks like 1.0.9 is the fix for our controller. I’ll report back if things break/change, but otherwise if you don’t hear back from me you can assume all is working :smiley:.
Thanks for this guide. I was trying to figure out how to get the 1.0.9 beta to see if it would solve my issue of controller failing to run smart schedule or sometimes run but not update soil moisture.
So far, mine seems to be working again as expected after applying the Beta firmware (1.0.9). Only one schedule has run since then though, so I’ll be keeping a close eye on things.
Ugh. I’m glad I’m not alone but I’m really unhappy about this. I’ve been a Wyze fan and user since day one and have a ton of cams. I added the sprinkler controller to ensure that our newly reworked lawn would be taken care of with the automatic schedule, especially when we were away on vacation. Needless to say I wasn’t too thrilled when I came back from three weeks away and had an over stressed, unwatered yard.
I tried to create a set sked to run every other day (I did this two days ago). Nothing, nada, even after turning off the default scheduled task.
When trying to force a quick run, I too experience the app showing that it’s running without the unit actually turning on any zones. I CAN run zones individually, but that’s a PITA and not why I bought this.
I’m very frustrated at this point; I’m a very patient guy but this is crazy. Wyze: What are you doing to fix this???
Are you running the latest firmware? I havent had an issue since they released the latest firmware and I have about 6 set schedules at the moment.
Schedules do not work; manual runs work
version 1.08,
log submitted, ID number 624440
Updated to 1.09, tried new schedule, still NOT working. manual start runs OK
The system used to work fine last year and when re-started this spring, but has stopped to work in the last 2 weeks (?) time…
HELP PLEASE, the grass is dying :frowning:
I’m also paying for the “PLUS”, but if equipment/ software is not working we need to review it.
@CLT_TechGeek Could you try updating to 1.0.9 beta? Anyone can join beta by going to the 2.32 Wyze app > Account tab > About > Beta Program > Enroll and select Sprinkler.
@ricardo.gloria Do you mind submitting a log now that you’re on 1.0.9? Since that log was on 1.0.8. Thanks in advance.
626851 @Shanee
Well, mine’s been working since I last reset power a week ago. It’s run every day but one (where it wasn’t scheduled). I’m on 1.0.8. I hope I’m not jinxing myself.
Beta 1.09 here , Chile, Master Valve + 8 valves , working OK for three days Quick Run and Schedules so far. I consider ok if for 10 days never fails, not still there
I’m having this same issue and I just got mine yesterday, I’m on the beta update and have done all the things in this thread. My log ID is 628794
@Shanee,
new log 629184, after updating to 1.0.9… short schedule did worked a couple of times, but afternoon longer schedule never worked.
Now, all schedules are not working; manual start works fine.
does shutting off the device for at least a minute and then turning back on resolve it? This stopped the issue before 1.0.9. Not to say it doesn’t randomly come back and you have to keep restarting it.
@Shanee
update, new log 629640.
The short schedule in the morning just worked. The longer in the afternoon, still not working.
Tks,
I have the smart schedule setup to run Wednesday and Friday and it hasn’t worked since May 20th either. I don’t even see any grey dot when it should’ve ran. I uploaded logs from 1.0.8 #629678 but I’ll try updating to 1.0.9 beta and see if it runs this weekend.
I also want to join the list of those reporting issues with the sprinkler schedules. I had sprinkler system turned off during the winter and had it turned everything back on in mid March…everything seemed to be working and the calendar in Wyze shows items are scheduled and it appears to be running when I go into the app to monitor but the actual zones aren’t kicking on the water. I’m on version 1.0.8 and submitted log # 629697. I can try the beta if needed but curious what is the time line before that gets promoted to general release…
Question for the group. Does your controller remain online or does it drop offline?
Every time I leave home my controller drops offline when it tries to run. I have no idea if the controller is running.
Works fine when we are in the same city.
