Can's record to sd card
WYZE V3 and V4’s: I have six cameras and all had the “record to SD card” option checked and all “unchecked” themselves sometime in the last 24 hours (11/17/2024 @ 5:00 pm EST). When I try to slide the button to activate the records to SD card, it slides “on”, but when I log off and check back, it is again unchecked. Anyone else seeing this or have a solution? Thanks! Jim
@nanosj,
By chance did your wyze app update to 3.2.5 591 in the last 24-48 hours. If so see the following thread especially @carverofchoice summary about cameras that are showing issues with this release.
Personally my v4 is exhibiting the SD card not sticking but if it makes you feel better the card is still recording regardless what the setting says. And it is viewable.
If this is not what your seeing let us know.
same issue, slider is not stick record to sd card option, although sd card is recording without problem.
I guess its the latest update of application. 3.2.5 (591)
THANK YOU EVERY ONE! This seems to be the case on mine also
