Cannot Get Into Detection Settings
When I select the detection settings for my Cam it never allows me to make adjustments. I just get a spinning wheel. In the past I hav been able to make adjustments but lately I just get the spinning wheel. No matter how long I wait it never goes away and I am unable to adjust the settings.
Have you restarted the camera? Have you powered off the phone for a minute? And checked that you have the latest firmware?
I tried those with no luck. I found a work around in the forum. Change storage to local and it works. Hopefully Wyze will fix it but for now I can at least change the detection settings. Thanks for your response.
Mike
