I have not kept up with what wyze has been doing, but I know one of the early issues with it is that you needed a phone, or a phone emulator to use a wyze cam as a IP camera
has that changed?
we have a local makerspace and want to set up some cameras a for a streaming setup and we want to use all IP driven cameras, and not have to add an additional layer by porting thru a phone emulator
This is a subject I admittedly don’t keep up with, but there is experimental software available for both webcams and RTSP.
I don’t know if the Webcam firmware was ever released for the V3, and I only posted a link to the V3 RTSP firmware (there is also a V2 version). In any case there are several discussions on the board about both:
While yes, the RTSP firmware is available as a separate installation for the V2 and V3 cameras, they still will want Internet access. To have a true IP camera you’d need Dafang Hacks firmware on the V1 or V2. I assume the webcam firmware would not suit your purposes as it requires a USB connection.
I installed the firmware, I see an option to enable RTSP, it says to ‘Open the uri below on your RTSP compatible video player while using the local network’ - but no URI is displayed…?
