I just purchased 2 WYZE Cam Pan devices and they are great, however, I would like to use my pc to check in on them. Is there and application for my desktop pc to do this?
Welcome to the community.
The short answer is no.
The long answer is, there are ways to do it.
Read this thread.
I like using bluestacks. It’s like having your phone app on your desktop. You can add and edit your rules and schedules, see all your events, etc. I find it much easier on the big screen especially if you are showing it to others. Some complain that it slows down their system, I have never had an issue with it, so you will just have to try it on your own system. Good Luck . . .
