Wyze cam for PC
is there a way to access wyze cam app from my windows 10 laptop, just to watch my cams on pc? some sort of android crossover to PC app?
Some people use BlueStacks, if you are using the Chrome browser you can also use ArcWelder. I know some people have achieved it
There are numerous solutions
but not within the Wyze app.
About the easiest for 1 camera at a time is RTSP and VLC. Took me about 3 minutes to download and boot from SD card then view the stream on my PC using VLC the last time. That was about third or fourth time I did it. It can be tricky timing and manipulating the cam.
This afternoon I recorded a 3 hour sunset sequence - took 1.13 GB
Search is your friend, lot’s of solutions, not all fit all people.
bluestacks does the job but it’s a resource hog
HUGE, resource hog, that’s why I quit using it
The thing about Bluestacks is that it’s a challenge to view more than 3 cams at same time. Sometimes I run 2 instances of Bluestack to see more cams but it’s not ideal.
Can you or anyone else here on the forum offer step-by-step instructions for using ArcWelder on a PC running Chrome to view Wyzecams on a PC?
If you have a subscription you can view your cameras in Web View.
On a side note, Windows 10 is no longer supported by Microsoft. Here is a video showing how to install Windows 11 25H2 on old unsupported hardware.
I am well aware of this, habib. I do not want to have to pay for yet another subscription just to view my Wyze cams on my PC. I am seeking this alternative method.
