I have an unused irrigation system where I would like to install cameras where sprinkler heads were previously used.
Pop-up cameras? What a neat idea! Actually, I wouldn’t think the wiring to the valves would go all the way to the sprinkler head. Don’t they put all the valves in a central location near the water source?
Yes, there are normally solenoid actuated valves in a central box. ![]()
Correct, and the heads pop up due to water pressure. Not something you probably want to expose the camera to. ![]()
Most sprinkler systems run on 24VAC. You would need a 24V AC to 5V DC converter, then wire it up to a USB socket.
I’m not endorsing it, but here’s one I found on Amazon:
As mentioned above, this would only get you to the valve box, not the actual heads. And you’d need to be concerned about waterproofing everything.
Guess I am confused. If you work out the power supply issue what next?
Are you trying to use the sprinkler timer clock to turn on and off your cameras?
What is your application?
