Sprinkler Controller
I just pre-ordered the Wyze sprinkler controller. Can I see the manual for the DIY instructions to plug it into my existing system?
I am new so excuse me if I posted this the wrong way. I am actually trying to get an answer from Wyze. Thanks
Check Wyze support page
@Jagi
Any support info that is currently released can be found here.
https://support.wyzecam.com/hc/en-us/categories/360004538771-Wyze-Sprinkler-Controller
Thank you Jason but I already went through that. I would like to see how to actually replace my present controller when I receive the Wyze controller. Diagrams, videos, or PDF/Docx.
I will bookmark this thread and as soon as I know of one being available I will link to it here.
**Note: I do not work for Wyze and am just a user that volunteers a bit of time so until the release it I wont have it either
Thank you, Jason.
Stay safe.
Is there a wiring diagram available? Specifically I’d like to see that there are separate terminals for a master valve. I don’t use a master valve with my current system but I take the 24 Volts off of the Master Valve terminals to drive a relay which provides on/off status of the irrigation controller via my home automation system. In the future I will likely use the 24 volts off of the master valve terminals to integrate into an auto shutoff system for my water mains. Therefore I need the 24 volts from the master valve terminals.
I did see in the photos on the website the master valve has separate terminals.
I’m glad to see Wyze develop a sprinkler product but please offer more Zones. 8 up to 16 zones are the standard from other companies and should cover most homes.
Thanks. DD
Can you post the link that shows the photos that show the terminals that are identified as Master Valve? I looked on the web site and I didn’t see anything that specific. Thanks.
