Hi!
Regarding the Wyze sprinkler controller system.
I need to know if the port marked as M is indeed what should be used as a control driver for a water pump for a well.
In other words, when any of the 8 zones are active, then the pump needs to be switched on. On many sprinkler systems, this would be 2 dedicated ports with 24v ac that would be active if any zone is on.
Would appreciate a 100% confirmation if this is indeed the case.
Thanks!
