I keep trying to scan the QR code on my iPad for the Wyze camera OG and it’s not recognizing it? Also the OG is not listed so idk? HELP
Sounds like you need an app update on your phone. In other words, the current app you have does not know the camera exists.
Yea, the OG doesn’t use a QR code, it uses Bluetooth. Make sure your app is up to date and make sure you click “Wyze Cam OG” in the add device menu, not anything else.
Directions: ![]()
After you update your app to the latest version, make sure your Bluetooth, GPS Location, and WiFi are all on when you start the install.
