Hi, can I route a flat micro USB cable in between a door to power my Wyze Cam? The gap is enough, but would closing and opening the door over time damage it? Thanks
Yes. I do it. Mine is 15 feet long.
Same answers from your other topic applies here too. Depending on how tight the door closes and how often you open and shut the door will be a variable in the damage or wear and tear over time. Applies to windows frames and door frames
