With the new Wyze Cam v3 being in/out doors, I’d like to mount some in my window corners, externally. So, I’m looking for some flat power cables that will not compromise my window seals, suggestions?
Do you have V2 or Pan cameras you can swap cables with?
Or, type flat micro USB cable into the Amazon search box.
https://www.amazon.com/Extension-WyzeCam-KasaCam-Charging-Security/dp/B07TKHLZHT/ref=mp_s_a_1_1_sspa?dchild=1&keywords=flat+micro+usb+cable&qid=1603996896&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFBWDdPT1NCTDdaTFEmZW5jcnlwdGVkSWQ9QTAzNjg0NzkxTkZURDFDREJZWVFaJmVuY3J5cHRlZEFkSWQ9QTAyNDEzMTMzRlkxQVE5OVdSQVY1JndpZGdldE5hbWU9c3BfcGhvbmVfc2VhcmNoX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
I think the v3 comes with a flat cable in addition to the attached rat-tail, but how long is it?
Well there ya go @dags it’s already equipped with a flat cable.
