Cam Pan v3 Cabling
How is the Wyze cam pan version three extended outdoors? Is there an extender?
You might wanna try these posts:
Welcome to the Wyze User Community Forum @Fxstsb! :man_raising_hand:
The Pan V3 comes with a special cord that only fits this cam. It is a right angle plug with a custom weather seal to fit the bottom of the plug.
If you need to plug this into and outside outlet, you will need to wait until the Outdoor Power Adapter V2 is released.
The 6ft cord with the cam can be run indoors and used with the supplied 2A power adapter or it can be extended with a M\F USB-A extension so long as the connections are indoors.
