I noticed yesterday that I am not able to enlarge my cam views to full screen on my iPhone. Has anyone else run into this issue?
There is another discussion about the same issue on the board someplace. It happened after update to iOS 16. Turn the phone and you will get full screen unless you have it locked in portrait mode.
Ok thanks!
Regards,
[Mod edit] personal info removed from email signature.
you should remove you phone number ASAP
Do a quick edit.
Hi @bryanbuck - sorry for the inconvenience. We are looking into fixing this issue.
Until the fix, if you rotate your phone, you can view the livestream/events videos in landscape mode.
This is also affecting iPads. When you try and get back to switch between live and recorded events, you end up with a option-free still image for recorded events, but a video stream for live events.
