I have 2 v3 cans and 2 v4 cams.
When i try to set them up as doorbell chimes in the duo settings, it only shows the v3 cams as an option…??
Is this feature not availabke on the the v4 cams…??
I don’t believe it is…yet. I hope they extend it to that model at some point, though. It’s not currently listed in the Help Center article. When only Video Doorbell v2 supported this feature, Wyze said that they “plan to expand this function to more Wyze Cam devices”, and they added Cam v3 support after that. I would anticipate seeing it as part of a Cam v4 firmware update at some point, but I don’t know if that’s part of the plan.
Hey Crease… Thanks for the (always expert) reply…!!
btw… I read one of your recent posts about "motion’ notification on the duo being hidden unless you choose All Events… they need to fix that in an update…!!
Hope all is well!!
Cheers!!
You’re welcome. I don’t consider myself an expert, but I appreciate the compliment. Thanks!
I’m not sure which you read, but if you mean the thing about “Complete Motion Detected” notifications, then I’m just trying to pass along what I’ve learned by reading what others have written, some of whom have suggested that Wyze fix the “hidden” option.
Thanks for the good wishes! I hope all’s well with you, too!
