CamPan V3 won't connect in WebView
I recently installed a Cam Pan V3. It connects and operates fine in the Wyze App on Android and in another 3rd party viewing app that I also sometimes use, but it will not connect in Wyzw Webview. I can select it and it displays the placeholder along with my other cameras (except frustratingly my video doorbell “Pro” that for whatever reason is still incompatible, but it will not connect in Webview no matter what I do. Is this another incompatibility issue with WebView? Has anyone else gotten their Cam Pan V3 to work in WebView? It works absolutely everywhere else, but not there.
Is there a cam plus license attached the camera?
Thanks for the reply. Yes there is. I have Cam Plus unlimited so all my cameras are on Cam Plus.
It should be working I believe. Does it attempt to connect? Or just shows a thumbnail? Any error messages? Some things to try and possibly a different browser? Remove the camera from CPU then add it back, then try the webview?
Well, I have no idea why but after a week it all of a sudden started working. I could not determine what the issue was, it just started working. Thanks for all the replies and suggestions. Sorry I can’t provide a more concrete answer on how or why it didn’t work and then it did.
