Camera Off Line
One of my cameras is offline and I can not get it to turn on or go back on line. I am on vacation so I can not reboot remotely or troubleshoot it remotely that I am aware of. Any advice on how to turn it on will be greatly appreciated. Thanks.
Don
The only way I know to restart the cameras when not home is to have them plugged into a smart plug that you can power cycle from anywhere. I have my plug in cams connected to smart plugs and the base station for the battery powered cams plugged into a smart plug. Is you camera outdoors? Maybe you could get some person to access it and cycle the power switch on the back of the cam (WCO) or pull the plug out of the back of the cam and insert again?
If you can get your on-site router to soft reset or refresh device connections, that might help. I was able to bring an offline Wyze plug and OG back online remotely this way.
Thanks for the reply but these cameras are battery powered with solar panels. The battery shows 100%.
Don
I’ll have to get a neighbor to reset the router. Thanks.
