Camera not detecting the important events
My camera (v3) doesn’t pick up obvious events like people delivering packages on the front doorstep and people entering the house. It detects traffic and walkers from further away, but that is all. it has never worked properly. We have an older camera version and thought the newer version would work better, but is actually worse. I have set up detection zones.
I posted here because I cannot seem to submit a log for help from the app
Do you have a grandfathered Cam Plus Lite account and have you added the v3 to it? If not, then the camera is limited to one event every 5 minutes, are the missed events happening in between other events that have reset that timer? If you have an SD card, you can see if it is triggering as it will record stuff that happens even between the 5 minute limit (even if you have it set to events only).
If not you would want to ensure your detection zone isn’t too specific and/or play with the sensitivity setting on the camera, possibly even the placement or aim of the camera.
