Hi, I’m trying to set up my new Wyze cams v2 (first time) and I’m having issues that I can’t find help for online.
When it says Ready To Connect, it succesfully scans my QR code and says “QR Code Scanned, Please Wait” and I press the button on my phone for it. But after like 6 seconds the camera goes back into yellow light and says Ready To Connect after like 10-15 seconds. If I let the 150 second timer run down, it ends with “Connection error, try again” or something of the sorts.
Can you measure the signal strength of your connection?
I’ve had that happen when signal strength was marginal.
That was when I was trying to hook up to to my phone as a hotspot. I moved the phone and connected.
The issue shouldn’t be with the connection as I was right beside my router. However, I ordered 2 and my second camera worked right away with no issues at all. I assumed the issue was that the problem came with a problem. I have returned it and ordered a replacement.
