Camera battery suddenly going from high percentage charge to 0%
Every update screws up more than it fixes!!!
Camera battery suddenly going from high percentage charge to 0%. Just started after last update. Night vision has gone to nearly nothing.
Not a happy camper with this brand! I now know why they are cheap.
Did this start right after you updated? Has it happened repeatedly, or just the first time? If so, how many times, and how long does it take to fully discharge. Once you recharge it, are you able to live view it and use it perfectly fine? Does it upload events (a normal amount) during this time?
