Cam V3 discount
I have been a Camplus member for a few weeks (on two cameras) and have been trying to take advantage of the $19.99 V3 promo to buy another camera that I will not need Camplus on, but every time I log in and go to shop, it does not discount the $23.99 price. How do I get the special price?
We to the Wyze community @garyspad!
Make sure you’re logging in, then clicking “shop”, then the V3 page. You should see the price of $19.99 for one V3.
Are you using the same email as the one that was used to purchase Cam Plus? Have you tried adding one to your cart?
There was another discussion on this. If you pick the V3 Camera only option, 1 camera, then go to checkout, the price shows 23.99. If you up the Qty to 3 it drops down to 19.99 per camera. Here is the other location: Price error of cam v3 - #6 by WyzeGwendolyn
BTW: @UserCustomerGwen indicated that this issue has been resolved. I did verify it was indeed fixed.
Thanks for responding. Yes, I was logged in with the correct email, verified I have two paid Cam Plus subscriptions, and went to the shop, but only the $23.99 price showed up. I just tried again, including trying to add it to the cart, and it still showed $23.99.
Do you see both options? V3 with CamPlus and the V3 only? The default is the one with the CamPlus.
Also, Do you see the adjusted Price? I never do unless I am logged in withe the correct account.
One other question, are you doing this from your phone or a computer?
Both the CamPlus and the regular V3 show at $23.99. I’ve tried it both on my PC and my cellphone, and cannot get the $19.99 to show at all. I even tried the other suggestion of putting 3 in the cart but they still show $23.99 each. I am definitely logged in before I go to the shop. At this point it is not the $4 but the principle of the thing. I tried to do this during my first two week free trial and was told i needed to be on the regular plan, so I purposely cut my free trial short and activated my i year subscriptions (that was another chore - even though I had paid for Cam subscriptions when I bought the cams, I had to “pay again” with the assurance I would not be double charged, just to activate.). At this point I will just hold off.
