Events only save for 14 days? That doesn’t seem long enough. Is there a setting for that or option for longer? Not cool! Also why do I have to choose tags for this post? None were relevant.
Welcome @siskaott
Yep 14 days storage with Cam Plus. you cannot change it. you can also put an SD Card in the camera and have it record continuously, depending on the camera you have.
Tags are required to focus forum members on particular topics or options. Also makes it easier to search. I changed it to Cam-Plus as that is more relevant than car.
If you want more you need to upgrade to Cam Unlimited Pro which holds 60 days. But personally I’d say it would be wiser and more cost effective to put SD cards in the cams.
